Rear Axle listing on window sticker
stew930
South Dakota
If the rear axle ratio isn't listed on the online window sticker should I assume it is 3.21?
Thanks
Statcher1
Kentucky
There should be a sticker on the rear axle somewhere. Otherwise you can request a build sheet from Ram.
S
stew930
South Dakota
Thanks
I should have added I was just looking online at a dealer and pulled up the window sticker. I may go down and peak at it in person to find out what it actually has.
KCTHUNDER
Kearney MO
6.7 CUMMINS
I think 3.55 is most common but ya go check it out!
Two Dog
Ontario, Canada
2014 RAM RCSB Express
There is an ID sticker under the rear axle tube, driver's side. It will clearly state the axle ratio. There is also a code that can looked up to determine if the rear axle also has LSD or Anti-Spin.
