rear end question
04SPORT
Elk Grove Village Illinois
I have a 04 1500 hemi sport and i see videos and pictures all the time with the same truck being able to spin both tires during a burnout and i can only spin 1..Why is that?
DavidRam
SoCal - Redondo Beach
2012 RCSB
That's how they came from the factory, it saves a little money. Though, it's a shame that they would do that...
I had 3.55 gears and an open diff, and I recently spent $2,200 to correct that. :(
Statcher1
Kentucky
It's a cost thing. Some people will never 4wheel the truck or drive it hard. So they offer a more base version of the trim level
DavidRam
2012 RCSB
^^^ True. But it makes a difference in traction even after a little rain with normal driving. One wheel traction, especially on trucks with the light rear ends, should be a crime. :)
Statcher1
Kentucky
Agreed 100%
04SPORT
04SPORT
alright i kind of figured it might have been a different model. It doesnt really bother me i dont plan on roasting the new tires i just got anyways:D
DavidRam
2012 RCSB
If it doesn't bother you than that's good. :) Personally, I got tired of roasting my tire half a city block before I got traction! Lol!
dmacell1
levittown PA
hemi 5.7 supercharged at 10psi
It cost me over 2k to get my rear switched out to a limited slip too. But with the supercharger it was barely driveable even on dry ground.
If traction isnt an issue i wouldnt worry about. An open end rear will last practically forever.
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
I am not a big fan of limited slip as to many times parts break, clutches wear out, or come apart taking out the bearings, and or the ring & pinion gears. I would rather have a Detroit Locker or leave it open carrier.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Traction control can be installed in your driveway with basic tools and does not require gears to be setup if you stick with your current gears. Traction can be a issue when adding power. Since you have a 03 check to see if the TMR mod has been done. Welcome to the forum and good luck with your new truck. 03's are special....
https://www.google.com/search?q=pow...F-8&oe=UTF-8&sourceid=ie7&rlz=1I7NDKB_enUS531
