Rear end whine
Josh Morlock
Ohio
I have an 05 ram 1500 4x4 that has a loud rear end whine while accelerating and cruising. At Around 35 the noise starts to get really loud and peaks at 45-55, as long as you are cruising the noise is there but as soon as you let off the gas it goes silent. Would this be a symptom of a bad pinion bearing?
J
Josh Morlock
Ohio
No leaks or anything, and last I checked the fluid was still full and it looked good.
zogg
Southern Illinois
2018 Ram Express Quad Cab
I’d suggest your ring and pinion are worn out. How many miles??
Wallyb4
Retired EWC(SW/AW) 1983-2003
Virginia Beach
5.7L
Is there any slop in your driveline? But I would agree with Zogg your ring and pinion is going bad.
J
Josh Morlock
Ohio
158,200. I checked the fluid again, looks really good. I’ll have to find a rear end somewhere.
I would go to a Driveline Specialties shop, they do rear ends, front ends & drive shafts.
They will remove the inspection plate, that also drains your fluid.
Then they can look for chunks of metal & look at the metal shavings, they also inspect the Ring & Pinion Gears, etc.
Then they will tell you if gears are shot, whether or not they can adjust the axle shafts to close up the clearance between the Ring & Pinion.
If you do need new gears, new gears can be noisy or less noisy
Good Luck with the findings
aRBee4863
Boise, ID
Oooh ooh! I know this one! Before you spend any money, check the rear differential pinion nut. If it's loose that'll cause your noise, I just tore apart my diff and swapped out gears while installing an LSD and the pinion nut was suspiciously loose and there were no metal shavings in the diff fluid.
aRBee4863
Boise, ID
So I thought my issue was caused by bad gears, but in retrospect it was probably that pinion nut getting loose that caused the issue. There's even been a recall (you have the 9.25, right?) and they install a pinion nut keeper. If yours hasn't been by for the recall, they might even do the work for free at the dealer? worth a shotRC-P77-15-49.jpg
