Rear spacers
jknappen
Kentucky
I see all these guys running rear spacers when running level kits bilsteins etc. what is a popular good quality .75 to 1 inch rear spacer and what does it take to install them?
AustinB
Banned
San Diego, Left Coast
Top gun customz would be the most popular
Takes about 30 mins of your time once the wheels are off.
IMO
AustinB
Banned
If you're patient. And really going to go forward with this, I will give you some 3/4" spacers for the cost of shipping, next week.
Otherwise I will give them to someone else that needs some.
IMO
jknappen
jknappen
Kentucky
IMO
Sounds good ill take them.... Thanks
JExpress14
Boston,MA
How's the quality of the topgunz read spacers I'm thinking about pulling the trigger on the 3/4" steel ones.
sausec17
Banned
ATLANTA
I used 1.5" TGC steel spacers for about a year. Very nice quality. I would recommend them.
AustinB
Banned
I think its safe to say that when it comes to rear spacers.. There probably isn't a bad quality. You're shopping for price and customer service.
A lot of people run and recommend TGC spacers. The only complaints would be that some claim that the steel ones cause "squeaking" noises and counter that with the poly material (like I have).
There are also guys with steel that claim zero noises.
IMO
sausec17
Banned
ATLANTA
If you use the steel rear spacer you are suppose to re-install the spring cushion which is basically a 1/4" rubber spacer. That removes the chance of any squeaking.
JExpress14
Boston,MA
So are you saying to remove the factory spring isolator slip the spacer in then put the isolator on the spacer?
