Rear Turn Signal Out Message
babyboy1105
SoCal
I’ve been getting “Left Rear Turn Signal Light Out” message with a rapid blinking turn signal but all my lights work. Anyone else ever encounter this? I have 14 1500 Laramie w/ 77,683 miles.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Assuming you have led bulbs somewhere (can even be the 3rd brake light) we will need more information to help you diagnose
B
babyboy1105
SoCal
I do have leds. They’re the stock. My left mirror turn signal blinks rapidly.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
did you change your mirror bulb? Is your 3rd brake light working? Does it do it intermittently or all the time? Did you replace any bulbs since you’ve owned it? Have you owned it since new?
B
babyboy1105
SoCal
I’m the second owner. I see the message at each startup and the message stays in my message center and will flash on the display intermittently while driving. The mirror light and turn signal arrow constantly rapidly flash. I did change the third brake light earlier in the year.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Take both taillights out and swap them to see if your message switches to the right side.
Usually if you have a signal light that blinks rapidly,you have a bulb out somewhere on that side of the truck.It's not always,but i'd look everything over really close on that side,to make sure all the signal light leds are lighting up
StoneDude76
West Chester,PA
Do you have a tailgate light bar?
Sent from my VS988 using Tapatalk
^^^ try this
The factory LED taillights have a separate "bulb out" wire, this could be causing the problem even though the taillight still works.
B
babyboy1105
SoCal
I’m going to try your suggestions. I appreciate all responses! I’ll follow up with what I find.
B
babyboy1105
SoCal
Update:
I checked out my turn signal. There are a few led lights towards the not that have gone out. I think the only remedy is to buy a new tail light.
