Rear under seat courtesy lights in Express bench seat
Duane Pipes
FL
Wanted under seat lights for the backseat. Got confusing trying to piece everything together. Truck is a 2018 Express. Started with my bench under seat lights journey with this thingy not connected to anything:
Ordered wrong connector 68186565AA. No bueno:
Ordered the right connector 68217325AA so making progress:
Then the bezel 5KX15DX9AB clips onto the LED light:
Connector w/ pigtail matches connector on LED wire 55057286AD then bezel clips on:
(Can only upload 5 pics at a time) Then wait for it...
Duane Pipes
Duane Pipes
FL
Then I pulled back the carpet on my 2018 Express...
There's nothing to connect it to! Haha
Puba08
Long Island
From what I read I thought the lights couldn’t be added????
Duane Pipes
Duane Pipes
FL
I’m going to add lights this week as well, are these the wires needed to get power to the rear lights?
W4ZWA, the green and white wires twisted together go to the sub. I wanted install oem under seat lights in the back. i pulled the carpet back and never found the wire for the light. Huge bummer.
Duane Pipes
Duane Pipes
FL
Yeah like 50/50 some trucks had the prewire for the lights. I know my 18 Express didn't.
W4ZWA
Central NC
2020 Classic
5.7L
Gotcha. My express has the plugs under the seat but no wires attached to them, I was hoping the wires were under the carpet to taped up somewhere on the harness.
Juanito1723
Chicago il
5.8 hemi
I’m also tryna to add the back seat lights, so if I order everything Duane pipes added, I should be good to go?
rixter99
SW Arkansas
2014 3500 SRW
Cummins i6.7
I bought some flush mount led's and drilled a couple of holes into the rear cup holder...I did have wires in the existing connectors under the seat, so I tapped into them under the carpet in the storage area...
TMFMK
