Relay questions
Urch
Mn
Can someone explain in detail why we need relays to operate aftermarket lights.
TMyers
USMC 84' - 92'
north wilkesboro, nc
Cummins 6.7
Some aftermarket lights use a lot of power or several amps. A switch and wiring would have to be heavy duty to carry this extra amp load. The relay acts as a "Go Between" where as the light duty switch and wiring only have to power the relay. Then, the relay powers on the lights using a heavier gauge wire supporting the required amp load.
CincyCuda68
Ohio
Well said!
muddy12
Indiana
Also, with a relay, you have the option to “ground trigger” the relay. Then you don’t have to. Worry about running “constant hot” wires into the cab.
Dennis Gulau
Central Michigan
5.9l, Ecodiesel, 5.7l
Technically, you don't need to use a relay, but if you don't, you need to use a switch and wires that will reliably carry the amps needed for the lights.
