Remove 6" RC dealer installed lift
Moparfanatic21
U.S. Marine Vet - 0321, Now a Doctor...of Vehicles
I think I'm just going to go with a AAA policy for flat tires and buy gap insurance from somewhere and hope and pray. Lol
Just ask AAA about the lifted truck. When I had them and a lifted truck (12" lift) they came and said we can't change that tire to high. So just double check so you don't pay for something you can't use. I've owned lifted trucks since I was 16 and drove them since I was 14 on the farm. We/I beat them and the maintenance isn't more then a stock truck, with the exception of the shocks and tires :) also gas lots of that lol
Jacamp
Jacamp
La Porte, TX
Oh, yeah, good point. Never thought about that. Yes, lots and lots of gas. Thirsty should be her name. Lol thanks for the tip![emoji4]
Moparfanatic21
Anytime partner!
JB1
Houston, Texas
https://www.roughcountry.com/dodge-suspension-lift-kit-332c.html?find=2017-dodge-ram-1500-4wd-375266
https://www.roughcountry.com/dodge-suspension-lift-kit-333c.html?find=2017-dodge-ram-1500-4wd-375266
If you look at the 6" kit instructions and compare them to the 4" kit instructions, there isn't much difference between the two. Looks like you could easily convert it to a 4" kit if that would help you, p,us allow you to switch to a smaller size tire without looking bad to drop it a little more.
FRONT:
The 6" kit uses a preload spacer and a top spacer while the 4" kit just uses the top spacer. So if you have that preload spacer removed that'll lower the front.
REAR:
The 6" kit uses replacement rear control arms and panhard bar relocation bracket which isn't included in the 4" kit but will work on either. Both kits use a spacer above the coil so I assume the 4" kit just uses a smaller spacer. Therefore you "should" be able to swap your rear coil spacer to the 4" kit rear spacer. Only other change would be to unbolt the bumpstop bracket and rotate it from the vertical position to the shorter horizontal position.
I'm not familiar with shops in LaPorte, you might have to drive to Houston.
Jace Auto works on a lot of trucks and they'll do just about anything p,us if needed they offer financing on everything. I would call and talk to them.
https://www.jaceauto.com
https://m.facebook.com/jaceauto/
CincyCuda68
Ohio
FRONT:
REAR:
Great info @JB1, my concern would be the replacement drop brackets on the diff, are they the same on both kits or does it drop the front diff more on the 6” kit.
JB1
Houston, Texas
Yiu would think they would be different but they aren't , if you click each link, scroll to the bottom, click the instruction pdf for each kit it shows the same part numbers for the knuckles and cross members.
Jacamp
Jacamp
La Porte, TX
FRONT:
REAR:
Wow that's awesome! You are my angel. [emoji72] I wouldnt have known what i trying to compare if I tried. Thank you so very much!
Reactions: JB1
CincyCuda68
Ohio
I didn’t spend that much time on it lol. But thank you for doing it, I feel for him.
@Jacamp looks like you may be able to lower this to a 4” lift very reasonably. See post above from @JB1
Jacamp
Jacamp
La Porte, TX
I saw it. I'm a she by the way. Lol Yall are just wonderful people. I moved to Texas in 2004 and I honestly don't get this kind of friendliness and helpfulness. I'm going to call that shop he mentioned tomorrow. See what they tell me. I'm excited to maybe see a light at the end of the tunnel. [emoji4]
CincyCuda68
Ohio
Omg I’m so sorry, almost all men in here but there’s nothin better than a chic with a truck!!!! I hope it works out, replace spacers in the rear and remove the preload spacer on the front!!!!
Jacamp
Jacamp
La Porte, TX
Yes sir, I'll getter done. Lol[emoji16]
MaxSteel2013
I ran into this same issue and ended up trading my truck in instead. This was only after I purchased stock steering knuckles and a replacement cross member (hundreds of dollars later).
Jacamp
Jacamp
La Porte, TX
Well, that is what I ended up doing. I traded her off. I was sad, but extremely relieved. Just too much for me to worry about. Especially when i am at the mercy of someone else to do my repairs.
southalum
