Removing crank sensor from my 1995 Dodge Ram v10
Hubbard george
V10
I have tried and tried to remove the old crank sensor. It just comes off in bits and pieces. Any hints???
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Don't hit it with a hammer to get it out :roflsquared:
But really, if its original the plastic is going to be brittle, however it should just come out, you may have a bolt still in the sensor holding it in, or it may have had dirt impacted and holding it in. Soak the area with penetrating oil and let it sit for a few minutes then try again. It should come out as an assembly not in pieces.
