Replacement Air Filter?
NEhemi_man
North Central Nebraska
6.4L
What is everyones thoughts on replacing the original air filter with a drop in filter?
Im looking at AFE and am especially intrigued by the inverted filter that fits in the rectangular opening but then acts like a cone filter with more surface area?
Also have read a few places about removing charcoal filter, thoughts?
https://www.autoanything.com/air-filters/61A4151A0A0.aspx
crazykid1994
The 6.4 air filter already flows pretty well. Quite a few of us 5.7 guys upgrade to that filter for a stock look while running a few bolt ons. I’ll be running it full bolt on because I plan on installing a aev snorkel which mounts to the stock airbox. Even the ecodiesel uses the same filter as the 6.4 and that’s a turbo diesel.
PG Air Filter PA99208| Fits 2019-20 Ram 1500, 2014-18 2500, 3500, 2019 1500 Classic, 2014-18 4500, 5500 https://www.amazon.com/dp/B07D2G1DY4/ref=cm_sw_r_cp_api_glc_fabc_3qFcGb0HM7K3D?_encoding=UTF8&psc=1
ToTheDarkSide
Eastern Ohio
Are the air boxes the same in the 6.7 Cummins and the the 6.4 hemi? The factory filters are the same
ToTheDarkSide
Eastern Ohio
hey brother did you end up getting the 6.7 style filter?
N
NEhemi_man
6.4L
No I never got it, I don't like being the test dummy. I think it would probably be the best option though don't you? The inverted come style
ToTheDarkSide
Eastern Ohio
I would think so. More surface area. It’s got to be tough being designed to have a turbo pull air through it at 50 psi plus. I understand not wanting to be the test pilot. But I kinda want one too.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4 air intake has restrictive bellows section, rough inner surface, and moderate filter surface area.
SB Filters flows app. 1/3 less restriction, according to their published bench data. I put theirs on mine. Seems snappier.
