Replacement speakers
EdGs
FL
2015 Ram 1500 SLT QC 5.7L 2WD
UConnect 5.0
What speakers to replace OE with least amount of modding?
AFAIK, just have the 6 speakers.
Thanks in advance
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
UConnect 5.0
Thanks in advance
The kicker upgrade speakers are great in my opinion. They come pre-wired for plug and play interface.
EdGs
EdGs
FL
Do you have the model # ?
They plug into the existing harness?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
EdGs
EdGs
FL
The 1" tweeters in the kit were enough for the dash? Not too bright?
So, 41's in the front and 28's rear, or vice-versa?
Any extra have to do's with these?
The 77KICK28ab are the front replacements, 77KICK41 go in the back doors. I went the same route and they're plug-n-play, you don't even need spacers like aftermarket versions do.
The tweeters in the dash are not overly bright for the dash.
To round out the system consider putting a Kicker Hideaway subwoofer under the back seat. Minimal wiring but everything needed is included and the power wiring will reach the battery even from the back of a crew cab. It's not window shattering but it definitely does help fill in the lower end.
KiloHotel
I went with Pioneer, if you order from crutchfield they will send the necessary speaker wire adapter for free. I left the dash tweeters alone, and it was a huge difference!
EdGs
EdGs
FL
What ones did you use on front doors? Back doors?
