Running board lights
CiggyByrns
US Navy Retired IYAOYAS
Houston, TX
6.7L Cummins
https://www.facebook.com/100002524662908/posts/3237027536391370/?
This is on a 2018 2500. Everything is wired “correctly.” I’m having this issue with the turn signals. When the running lights are on, they work perfectly. When they are off, this happens. The entire bar flickers and the sequence only runs half the length of the strip. Also, when I unlock the truck with the fob, the courtesy light doesn’t come on. When I open the door, it does. I connected that to the yellow wire with the purple stripe in the harness that goes to the truck mirror courtesy light.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
It looks like you have it wired for sequential turn signal. If there is a turn signal wire try to leave it disconnected. It doesn't illuminate the whole length during the sequential portion because it's not powered long enough to complete it's sequence by the turn signal power source.
CiggyByrns
CiggyByrns
Houston, TX
6.7L Cummins
...but it works when the running lights are on and I turn the signal on. The full sequence. It’s weird
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I see, that is strange. Maybe if you set your turn signals as DRLs you could set it and forget it. Do you have AlfaOBD?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Do I have a what? Lol
AlfaOBD is an App that allows you to enable many factory options on FCA vehicles, one option being daytime running lights (DRL).
