running boards
stretch
Hemi 57
got a free set of running boards from a friend cause he got other ones but he cant find the bolts ive been searching online but cant find them anywhere so i assumed this would be the best place i went to dodge dealership but they said u cant buy them without buying everything.. here is a pic of it a lot of ram running boards look the same any help would be great.
S
stretch
Hemi 57
there is another picture
I need like 8 big bolts with some sort of nut on the inside since the ram just has nut shaped holes and 8 small bolts that will screw from the 2 small holes on the rocker panel into the running board mount..
S
stretch
Hemi 57
if anyone has these running board and u can please take a picture of how they are connected to your truck maybe I can get a better idea of what im looking for. Thanks
S
stretch
Hemi 57
any pictures will do
e9muzik
If this is for a standard mopar set the part number is 68044460AA thats the entire Kit. with 12 M8 Riv-Nuts w/ 12 Bolts ( I would assume that the hardware matches other kits but unsure )
S
stretch
Hemi 57
hey thanks that's the kit I needed but its missing the small bolts I can prob get them at any hardware store.im thinking I might need 68193128AB but I cant find whats in it anywhere.
five_7_HEMI
I signed up just for this post as I was in the same position as you are (were?) ...
Every mention online suggests you need 68044460AA [includes 12 bolts and 12 rivnuts]. There is little to no mention of 68193128AB or what it contains. I just picked it up on lunch and can confirm it comes with 24 bolts and 12 rivnuts AND the rivnut install tool! It looks to me like the kit you would get in the box if you were to buy the running boards new as it has everything you need in it.
The price I got for 6804460AA was $46 + $15 for the tool [$61 total!]. 68193128AB was $39 [still not cheap IMO]. This makes absolutely no sense to me but is what I discovered after a number of phone calls.
Hope this helps,
Andrew
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Just ran into this same problem for my 2014 CC.
The correct part number was 68193128AB.
The dealership charged me $29 for the kit and $36 FOR THE TOOL....
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Picked up the parts this morning from my local dealer. Fortunately I decided to open the box of bolts and certnuts. The package contained the tool needed to install the nuts, so 68193128AB had everything I needed. I got my money back for the additional tool they had ordered.
feets
