Set Bils to 2.1 or 2.8?????
fire101fighter
South Jersey
So finally getting the bils put in on Saturday and the rear TGC .75” rear spacer too. The question is, should I set the fronts to 2.1 or 2.8? The truck has 93k on her at this point and everything is stock with no issues that I can hear/feel/see. I do have a solid 3” of rake as well. In all of your wisdom, what would be your recommendations and why? Thanks fellas!
BiGMERF
2017 SLT 4x4
v6
i did mines to 2.1.. i did it that way cause i dont mind a lil bit of rake
markusaf81
I did mine to 2.1, had a little less then .75 inch of rake (rear was slightly higher) after install.
IN MY OPINION, with the bigger hoods on these trucks, if they sit perfectly level I think they give off the appearance that the front sits higher.
But, I recently did new springs and shocks in the rear and got another .5 inch in the rear and I think it looks good.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
I went 2.8 and put nothing in the back. It eliminated the rake altogether. I have a factory 3” rake. I later lifted the truck 4” Zone with 3” rear coils, and cranked Billies down to 2.1, and put in Zone UCAs.
Later, I pulled the 5100s, swapped in 6112s, set them to 2.2 and went with Zone 6”. I am putting a 1” rear coil spacer for level, as I am nose high. @markusaf81 is right about the hood offsetting the rake, optically.
fire101fighter
fire101fighter
South Jersey
So if I got 2.1 on the bils with the spacers in the rear I should have about 1” of rake and look pretty good?
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Depends on your factory rake and of course your opinion!
fire101fighter
fire101fighter
South Jersey
I guess the main concern is if I go 2.8 would I have any issues to worry about?
markusaf81
From what I have read, everyones truck is slightly different...youd have to measure to get a better idea of before and after rake.
My original plan was to do 2.1 in the fron and .75 spacers in the rear. I'm glad I waited since the new springs and shocks gave me a half of an inch of lift.
As far as 2.8 and "concerns," Some guys say change UCA's, some say its fine, some say its fine but don't do heavy offroading....I would assume 90 percent of us are safe with 2.8.
fire101fighter
fire101fighter
South Jersey
Yeah no heavy off reading here, just when needed for work or on the beach maybe
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
I ran 2.8, no spacers, factory UCAs and 305x50x20 tires with no problems. I went off-road a few times in Ocotillo Wells, CA in heavy rocks and sand dunes, no issues. But when I later lifted, I did upgrade those UCAs.
Pull Ya
Cedar Creek, Tx
In the reading that I have done, most people seem to recommend that if you go to 2.8 it is better to replace your UCA's. I set mine at 2.1 and replaced my UCA just cause it made me "feel" better and would prevent any problem that might happen. That's a little over cautious but like I said it makes me feel better.
Jay
fire101fighter
fire101fighter
South Jersey
Think I’m gonna go with the 2.8. Truck is a 2010 and has no issues with handling now. Plus with the 3”+ of rake it might not be enough at 2.1 with the spacer in the rear
JB1
Houston, Texas
I agree, if your adding a rear spacer, go for the 2.8 setting, if no spacer go with 2.1
fire101fighter
fire101fighter
South Jersey
Bils at 2.8 with the 3/4” spacer in the rear
I’ll get better pix when the weather breaks
JB1
Houston, Texas
Looks good, that’s an altitude adjustment
