Should I buy?
cxvguy
Hi all, new to the forum.I am looking at buying a 1998 dodge ram 1500 4x4 5.2 liter engine truck.It has a 7'' skyjacker lift,2'' leveling lift,37'' interco m16's,20'' moto metal wheels,and spray in bedliner.It has 155,000 miles.Exterior and interior look good.He is wanting $5200..is this a good deal or not?What are the pros and cons of this trucks engine,trans,and drivetrain?This will be my first vehicle(I'm 17)and first dodge.All opinions and help welcome, thanks.
Metalizer
Pearland
Sounds like a mall cruiser being only 2wd. Also hope he geared the truck in the rear end to turn those big tires.
Merc225hp
NA
truck
gas
Welcome to RF :)
A few things first
Get a compression test done before you buy it.
Read the Plenum sticky thread.
Unless the gear's have been changed it will be a slug.
It won't steer like a newer truck/car.
It won't handle like a newer truck/car
Then you have to feed it and thats a big 4wd truck it won't be cheap to run, I would guess 8-10 mpg city/hwy.
C
cxvguy
Thanks for the advice guys..where can I get a compression test done?What gear ratio do you recommend?
Merc225hp
NA
truck
gas
Any good garage/shop can do one for you, expect an hours charge for labour. Gear ratio for 37's=4.56, $1000+ for both diff's to be changed. Lots are going to say you need to upgrade to the Dana 60+ diff's and they would be right. Look for a lifted 2500 gas or oil burner.
C
cxvguy
ok thanks.I'll check it out..
