Single to Dual zone ATC with donor vehicle
RamMan85
Home
I have a 2014 Ram 2500 SLT 5.7 with a RA5 radio. I have added Remote Start and Backup Camera. I have access to a donor vehicle, 2014 Ram 1500 Longhorn gas engine. The 8.4 (unknown whether it was Nav) radio has been taken but I have access to the dual zone ATC control panel, 7” EVIC, dual zone air handler under the dash and most everything else on the truck except the 8.4 radio. I am taking all the above components along with the sunlight sensor and temp sensor. What other modules/wiring will I need from the donor vehicle to swap to mine? I won’t be taking the heated wheel (wrong color) or seats (gone). I intend to put a 8.4 Nav radio later on mine. Will the dual zone ATC and EVIC work now without the 8.4 radio? Thanks.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
@Mpgrimm2 can tell you what you need to pull and also make/sell you any missing conversion harnesses you may need for your specific setup.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Sent a message
