Slight jerking when shifting into 4th (2012 Ram)
Tyrant
'12CC / '15RCSB
hey guys,
I have a question for the guys with the 2012 and 6spd trans.. when the truck shifts into 4th do you get a rough shifts or a jerking kind of motion?
It only happens when shifting into 4th at low speeds about 40(ish) mph or when the rpms are low, at high speeds or when the the rpms are high the shift is much smoother. Also all other shifts are smooth with now issues at all.
would appreciate and input :).
How many miles are on the truck, did it always do it?
T
Tyrant
'12CC / '15RCSB
About 9k miles and to be honest i cant remember it being this much, and i really only noticed it over the last month or so. Thought it was coz of the DSP, so uninstalled and drove around for 2 weeks without it and still the same.
looks like i'll be asking the dealer to look into it on the next visit. hopefully it isn't bad.
Yeah, your kinda stuck, if you were outta warranty or close I'd say upgrade your valve body to a Sheridan. You can switch out old fluid and try running Redline tranny fluid, if you have a sticky clutch that would likely cure it, but you can't risk doing anything to your warranty so you are kinda stuck as far as upgrading it goes.
20hemi10
SC
5.7L HEMI
My 2013 6 speed does the same thing and feels like it bogs at the same time only in that gear.
BlownGP
Houston/Baton Rouge
Probably the MDS
Mines kinda jerky at 40mph. It also feels like the computer doesn't know weather to de-activate the 4 cylinders or not.
20hemi10
SC
5.7L HEMI
I have MDS disabled with my BullyDog still have the issue.
T
Tyrant
'12CC / '15RCSB
Probably the MDS
disabled mds with the DSP, same jerking motion. actually feels less jerky with MDS enabled.
BlownGP
Houston/Baton Rouge
Umm, I do think these trannys could use a way better tune from stock.
MikeP
Brooksville FL
My 2012 SLT has don't it since about 30,000 miles. I am at about 45,000 now its still there but has not gotten worse.
emjohn4
My '12 has done it since new. 14k on it now.
I've had it to the dealer, they "don't feel it."
It seems worse with the MDS, but even with the MDS disabled, it is slightly smoother, but still there.
My '02 Durango with the same transmission shifts way smoother than my '12 Ram - which leads me to believe it is a combination of MDS and torque management - meaning it's "normal" and learn to live with it.
BlownGP
Houston/Baton Rouge
I hope to get a superchips soon and see if it fixes the problem.
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
My 2012 RT does it even with my Bully Dog and MDS turned off.
I got on it hard the other day and heard and felt a pop. But nothing seems broken. Still coverd by warranty so I guess I'll drive it until something fails.
Will post results when it does.
Dale_K
Not all 2012's do it. Mine is bone stock and shifts smooth in all the gears at 8k miles.
