Anybody see the fast n' loud show where they put a hellcat motor in a old dart? They couldn't get it to start cause the computer needed some work, they called the hp guys and they couldn't figure it out so they called the diablo guys and they got it no problem. That was when I saw Diablo is the **** compared to anyone else.
That wasn't the question boys and girls,i've ran both and both have their benefits,what I want to know is how much more can be gained from stacking them as one tuner has succeeded in doing.
HP Tuner and Diablo stack works well and allows more performance on some models.
Still prefer Diablo in most cases and if needed only use the HPT for parameters Diablo doesn't. HP has more parameters on the engine side in most cases. But Diablo is simpler to work with.
Soon you will see HPT start gaining ground. And yes I could easily take a truck with a solid setup and make it run similar times with HPT, anyone that says otherwise doesn't know what he is saying.
Jay Greene
Greene Racing
Say you get a recall notice. It's not unreasonable to think you could spend 20 minutes on both sides of the appointment tuning. Forget to do that and the dealership flashes an update on you then you've got 2 expensive paperweights to unlock. Not worth it IMO.
Just to clarify.
I have a 2015, and a new (unlocked) PCM. It was my understanding that all I needed to do was swap them out before going to the dealer. Will I have to have the tune redone if they do an update?
If you swap pcm you're golden for dealer work. The only reason you would need to do that is if you wanted the update on the tunable pcm. Say a transmission update came out. I believe diablosport buys the factory calibrations and makes them available to load with their tools.
So if something needs to be updated on my tuned PCM I would ask Diablo if they have it, then get the tune loaded to the Trinity, download that tune, send to HF, have them apply my tune to the factory one, and reload it?
Just trying to make sure I understand how this all works. I'm from the time when tunes were done with a wrench and screwdriver...
