- Joined
- Jan 17, 2016
- Posts
- 23,877
- Reaction score
- 54,971
- Ram Year
- 14 Sport
- Engine
- 5.7
Thanks for the tips, I actually did upgraded the clamps and had some connections welded at the exhaust shop. Is vband clamps what you used? I am not apposed to changing them again if that’s the solution, does anyone recommend a certain style of band clamp and brand? Sleeve style? Lap joint? V-band? And I have the bolts about as tight as they will go on all clamps with and impact, hand tightened first to make sure the aluminum spacer in the middle sits right.
I think you might be farther ahead pulling them off and wrapping them.It's pretty common for the knock sensors to pick up the exhaust pulse ping in the primaries.You've pretty well went through everything else,about all that's left is to wrap them.Plus you'll keep more heat in the primaries which promotes exhaust scavenging,and you'll have less under hood heat to contend with.My headers are double wrapped and the rest of my exhaust system is wrapped back to my X pipe,i use the mufflers as a poor mans expansion chamber.If you decide to wrap them an old tip is to soak the wrap in water before using,it'll lay alot nicer,and it's alot nicer to work with,not quite as itchy to handle.
