THRobinson
- Apr 19, 2018
- 167
- 11
- Location
- Zurich, ON (Canada)
- 2003
- Hemi 5.7l
New hood supports installed so had a chance to check the fluids in more depth... When it was safetied the mechanic said he aded some steering fluid because a bit low, checked today and was at the low line. No idea if leaking or just didn't add that much... Don't see any leaks... Will have to watch it.
I did however notice that it wasn't red like atf fluid... It looks like regular steering fluid, the colour of cooking oil.
Could it be leaking out because the wrong stuff? I'm not sure if the viscosity is different, maybe thinner and leaking through seals when in use? But, I assume that it is a good idea to flush it out and use atf+4 like it's supposed to be?
Could this have damaged it?
