Stock muffler
Musky Mike
NC
Has anyone cut open a 5 Gen stock muffler?
pacofortacos
Purpose of doing this? What are you hoping to see?
pacofortacos
The 6.4 muffler is a little different, in the fact that it has a flapper in it.
But the 5.7 is, I would have to guess, just like every other chambered muffler.
We will await your pics after you cut it open :)
Musky Mike
Musky Mike
NC
What does the flapper do?
pacofortacos
Makes it very quiet :)
It may create a little bit of a restriction at low flow for maybe a bit of backpressure - but this is just guessing.
When a STOCK 6.4 hemi (3.5" diameter) muffler and tailpipe are installed on a 5.7 hemi (3" diameter), it is whisper quiet - almost stealthy lol
Musky Mike
Musky Mike
NC
So quiet at idle and loud when get on it?
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
The 5th Gen 5.7s now have a weep holes in both resonators, makes aftermarket mufflers sound like there's a leak. I would absolutely weld it shut or remove the resonators all together.
Otherwise, pretty standard 40" chambered muffler tuned for MDS like the 4th Gens.
TheKenster
NH
I didn't know that. That explains why my magna sounds strange at idle if you listen near the tailpipes.
Sent from my SM-N950U using Tapatalk
pacofortacos
No 5th gen's have the bumper twin tailpipe outlets any longer??
Muffler design is most likely still similar to the 4th gen. My 4th gen is single in and single out.
Bowler807
Butler, PA
Someone asked about the flapper in the muffler of the 6.4. My E36 BMW has a flapper also. It is located in one of the muffler outlets. It operates on vacuum, and was placed there for a boost in low end torque. Sounds strange, but it works. I blocked mine open for a while. I had significantly reduced low end "pull". Once I re-connected it the car ran very nicely again. I suspect the 6.4 uses it for the same reason.
Musky Mike
Musky Mike
NC
Depends on the model, some have a single tail pipe and some have the dual tail pipes. On pre 2019s the muffler was single in dual out, (excluding single tail pipe models) on 2019s dual tail pipes, it is single in, single out with Y pipe making it dual tail pipes.
Fatbob Frank
Mc Gregor, Iowa
6.4L
And I for one thank them for changing it!
Makes it much easier swapping that huge pig out for something better...
pacofortacos
Ok, I haven't been under any 5th gens yet. thanks
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
Correction, I had to pinch and tack weld a total of 4 weep holes on each resonator for my FIL’s 5 Gen. It helped deepen the tone substantially.
Lemniscate_Mike
