Stock Sirius Antenn
ramwad
Labelle
Is it true if I replace the stocks HU with a DVD/Sirus/Nav unit the OEM Sirus antenna can be used for the Nav piece also. My ORM unit is only Sirus and I am looking at replacing it with a full all in one unit. 2012 Ram 1500 and I just can’t do the OEM radio. Thanks for the input.
TomT
SoCal/OC
I think PAC makes an adapter for that. It may have also been iDataLink. Do some searching and plan it out before doing anything.
adurm
FL
2015 RCSB
Thought i read you could trim the oem plug. You might still need an xm tuner.
barracudadave67
Burlington WI
Yes that is the one you need, that emjohn linked to. You will also need a SiruisXM tuner also. The tuner number is 300 something. I just did the whole swap out, to Pioneer HU, and SeriusXM tuner. Get a parking brake bypass, to wire in with the harnesses also, if you get a touch screen. You can get them on amazon.
Dave
Dusty_Ram
I just put a new head unit and Sirius tuner in my truck and crutchfield had to send me 2 of those adapters but neither worked so I had to use the antenna with the kit :(
ramwad
ramwad
Labelle
Thanks, I am still a few months out before the audio is done. Planing and making sure all avenues are cover. Thanks!
Djoker04
Ram 1500 2015
HEMI
What Unit did you install and what yr Truck? It should of worked....
Dusty_Ram
It should of been a direct fit and worked...what happened when you plugge it up with the Adapter antennae
When I used the adapter the radio said something like no signal or something like that but as soon as I plugged in the new antenna it worked
adrianp89
Tampa Bay, FL
The antennas can be finnicky. If you notice on the SXV300 there are notches on the side. This is to zip-tie the wire to, zip tie furthest away from the plug, and snug it tight. Then zip tie closest to the plug to put some stress and bend the antenna plug down a little. This will ensure you have no issues.
