sullivan
- Feb 12, 2011
- 1,929
- 101
- Location
- Houston, Texas
- 2016
- 5.7 Hemi
Where should I implement the LEDs?
upgrade your alternator and better batteryfirst a second battery will just cause extra strain on your stock alternator might make problem worse, when vehicle is running your alt runs everything, headlights dim because alt isnt producing enough amps, did you do the big three and run bigger charge wire from alt to the battery?
Would a capacitor work?
Sent from my DROID X2 using Tapatalk
capacitors do work despite what alot of people think but only if your problem is small if you are draining to much power and on long base notes the capacitor will drain down and your amp can actualy cut out, if he has the 136 amp alt its not big enough, what is the truck actualy doing? how much is the voltmeter moving at full tilt with low long bass notes?
Don't bigger alternators not work in these trucks due to the computer holding it back either way?
- Sent from my iPhone using Tapatalk
My power wire and signal wires are ran on separate sides,
Its only when I plug the RCA's from the headunit into the sub amp, then I get a werid sound from the door speakers as well.
For now, I have a few things to do:
1: Redo headunit ground, because the stock headunit grounds suck.
2: Redo amplifier ground, current location my suck.
3: At the rear where my power and rca's meet, Ill seperate.
If none of these work, ive read pioneer headunits have a fuse and when they go out they will give you a ground issue like what I have. The fix is to ground the RCA's to the headunit chassis.
Something else, I have 100amp midi fuse at the battery and at the rear I have a distribution block going to both subs, with 100amp midi fuse for each. Is that drawing to much power?
Does anyone make a h/o alternator for our trucks?
