Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 236 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 994 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,779
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Glad to see you two come in. Look over my shoulder on this thinking. I have spent time reading about this issue. Those members who replace their valve train with an aftermarket kit. We have no post, that I can find saying they had another problem. A roller cam kit comes with cam, rollers, lifters push rods and springs. Is that correct? If that is solving their problem it makes me think about the spring pressure. I know we have been suspect of the quality of the lifter parts,,,but maybe it is simpler than that.
R.L.K.
Bristol , Tn.
Im staying with 5W-30, but the PUP still hasnt quieted down.
Giving it to the end of July and if its not better Ill be going to PYB. Pains me to buy it, because its not very much cheaper than PUP!
PUP & PYB are great oils , but if your 5.7L is noisy then 5W-30 Redline oil should be considered heavily Sir , as it's been proven too many times to count here an the Ram Forum
Ramnewbie
JMO but I think aftermarket kits, even in a stock grind, are primarily produced by a high performance company. I'm thinking their quality insurance inspections would be more stringent than what is required for OEM. I know that if I have to replace mine after warranty that there is no way I'm putting OEM back in. If you go with even a mild cam will that necessitate getting a tune or will computer just pick it up?
Sent from my XT1650 using Tapatalk
Fitz-0518
Veteran 66-68
Central California
My tech just stopped by to have a beer. He claims, the early Hemi engine can take a mild cam upgrade with out a tune. The ECM was not as sensitive or sophisticated. The later Hemi's do require "program adjustment" for best performance.
Fitz-0518
Veteran 66-68
Central California
The valve spring has to have sufficient tension to keep the lifter in contact with the ramps of the cam. More aggressive cam profiles need more tension or things get ugly in a hurry.
Would you say our Hemi cams are aggressive. What I am stuck on is a suspicion that the valve spring tension/pressure "maybe" to high for the rollers.
tjfdesmo
AZ
TBH, I don't have an answer for you on the cam profile. As to spring tension causing issues, it's usually the reverse, as in inadequate tension and/or improper material, etc. allowing valve float. Everything has to work together as a system. That's what the engineers are supposed to figure out:rolleyes::rolleyes::rolleyes:
On Edit: The rolleyes smilies were directed at mother MOPAR for leaving us holding the bag on these mysteries.
Fitz-0518
Veteran 66-68
Central California
Thanks. Helpful information
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Sorry I have been on vacation and very busy. I sold the Ram to a friend on vacation. If you want something I had on it I kept some of the mods to resell so message me on that. I’ll try and get back on here when I get back from my work trip to Utah.
huntergreen
I suspect i
What did you replace the ram with ?
grizzstang
Calgary, Alberta Canada
So what are you going to drive then?
Dam huntergreen beat me to it!
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Looks pretty clean for an ten year old vehicle!
It is and I know it is dirty to own a GM but Ram doesn’t have anything big enough for my family. If they made a Ramburban I would buy it. I paid cash for this so I am happy. The 6.2L sounds amazing but geared the way it is my Ram would smoke it.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Lol that is not old .:)
It is when you travel for work and put on around 20k a year but I just need it to last me a little while then I’ll get something newer.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Always wondered why Ram did not build a Suburban.
Me too. I looked at buying a nice newer Suburban or Yukon XL. I just decided sticking to my Dave Ramsey plan was better. This has AWD and I prefer that for life on the road and barely ever off road.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I have a pedal commander for the Ram I don’t own now which has been used 2 days. Dang it!
