Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 254 8.4%
  • Royal Purple
    Votes: 344 11.4%
  • AMSOil
    Votes: 428 14.2%
  • Valvoline Synpower
    Votes: 174 5.8%
  • Mobil 1
    Votes: 1,077 35.7%
  • Other
    Votes: 737 24.5%
  • Total voters
    3,014
Burla
2010 Hemi Reg Cab 4x4
Then keep running **** thin oil, it's all good.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
DEF, what a joke. My work truck is all jacked up right now as it wont regen I haft to take it in to the shop tomorrow.
26' box, 6.7 Cummins auto and detuned like freaken crazy..lol
Ramnewbie
Yeah I hear you, that would suck! The code for it is P1521 but looking that up seems to bring up a lot of discussion about bad oil pressure sender's that are showing 99psi.
[emoji848] humm, is that a way for the dealer to change a part and then blame it on you for running the wrong oil? Oil pressure sender don't cost squat, but add in an $80+ oil change and everything's right with the world.
Sent from my XT1650 using Tapatalk
U&A
2016 3500 SRW
6.4 HEMI
The real news coming out of FCA is the newest lubrication is ****, because ***** (DEF) worked so good for the diesels smog they are gonna give it a go in the oil pan. No more climate change, just take your ****** out of filler up. I'm not sure what woman truck owners are gonna do, not my problem there. That is about as silly as their current oil specs.
DEF UREA and Water, or better knows as **** and water, but the blue dye really makes the def.
LOL we buy deionizedd water for our lasers all the time. Hay syn, ill make you some def and sell it to you at 50% off. You can get deionized water at your local “water store”
Ramnewbie
When I had my Dakota I had a front wheel bearing go out. Took it to the dealer for warranty repair and they did everything in the world to try to sell me a brake job with new rotors because mine were " pitted". I don't know what x-ray machine they were using to see the pitting but I couldn't see a damn thing. Finally had to get a little pissy and just tell them replace the damn bearing.
U&A
2016 3500 SRW
6.4 HEMI
The pitting acts as milled in rotor cooling slots. And grabs the pad better increasing your stopping ability.
:33::33:
:anitoof:
Stefan N
Sweden
2015 Sport
https://go-girl.com ;)
Burla
Dual use, just make sure you wash it before using it as an oil funnel.
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
Well that all escalated quickly lol. Need a new thread for DEFchat now.
R.L.K.
Bristol , Tn.
My bad , this was my response to about 20 post back .....since this new update I'm not receiving any updates on this thread .... frustrating!!!
huntergreen
Marine Corps Navy Badge
With not only considering hemi tick, but actual cam fails and internal problems we are seeing, I am glad I am with the stoutest thing I can find. Maybe it will or wont matter, but I feel like even if my cam fails I did all I could. Filters as well, what a find with those RP's. Maybe we should have gone even thicker, but I'm just not that bold.
On another forum, a 13 had a failed rocker wipe out a cam lobe. Didn't get an answer on what oil was used. Cyl 5 was the culprit.
Not rocker, the roller caused the issue.
Ramnewbie
Do those come in sizes? S,M,l,and XL? Jus sayin
