Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 238 8.5%
  • Royal Purple
    Votes: 328 11.7%
  • AMSOil
    Votes: 404 14.4%
  • Valvoline Synpower
    Votes: 161 5.8%
  • Mobil 1
    Votes: 1,002 35.8%
  • Other
    Votes: 664 23.7%
  • Total voters
    2,797
mcamzr
Dumb question maybe, but can you put a oil catch can on a 2005 hemi or only the new ones?
TheFactor
Oregon
It seems I'm getting my the same results as far as 5W20 Redline and how quiet and silky smooth it runs . If I Towed like you do I'd probably go 30W also so you probably made a good choice unless you get the evil low oil pressure warning message lol .
R.L.K.
Bristol , Tn.
It seems I'm getting my the same results as far as 5W20 Redline and how quiet and silky smooth it runs . If I Towed like you do I'd probably go 30W also so you probably made a good choice unless you get the evil code warning lol .
If I do get any messages I'll just drain out a couple qts and cut it with the Redline 5W-20 ! That's my plan anyway ...
Burla
2010 Hemi Reg Cab 4x4
Or just turn off your mds.
Hemi395
Cape Cod MA
I don't think you will. Sounding more and more like Chrysler specifies 5w20 for fuel economy than problems with MDS
R.L.K.
Bristol , Tn.
I pay a lot of attention to the evic mpgs , so I'll know in short order if my mpgs go down !
My evic # are typical for this time of year 19.5- 20.2 for all around driving.
Hand calculated is about 17.5 -18.5mpg
Nutshell
Keep us posted with the results. I've wanted to do 5w-30 but people on the internet say it will ruin my MDS and make my motor explode into a firey mess.
TheFactor
Oregon
Yep , several people running it with no issues. ..
I'll have to check my owners manual but I'm pretty sure under recommended oil weights it states use 5W30 when towing or hard use but could be wrong .
R.L.K.
Bristol , Tn.
Will do sir !
TheFactor
Oregon
Just get a fire extinguisher and stay off the net and you'll be fine
mcamzr
This. For sure right from a friends mouth that works at Mopar.
Nutshell
My motor has developed a tick. It's strange as it can sit for a week...start up is quiet. If I let it sit at work for a few hours and say I have to move my truck to let a service truck out (run time of less that 1 minute) when I go to start the truck to drive home I get a 3 second bleed down tick. Very strange as it doesn't happen all the time. I just changed from PUP to Amsoil SS. It's done this since the truck was new and I'm at 7500 now.
TheFactor
Oregon
H
That is strange ???
I've got only almost 3000 miles but no tick since day one . Glad I went with Redline oil though for its first oil change as preventive Maintence as I've read it's cured it on those with the tick so figured it could stop it to from happening to start with.
Hoping anyway .....
Nutshell
H
That is strange ???
Hoping anyway .....
It hasn't done it in 4-5 days. Hoping the switch to Amsoil would help. I'm going to give it some time. If it doesn't work it's Redline 5w-30.
TheFactor
Oregon
Amsoil as I'm sure you know is great oil also . I hope it works for you man but at least you know if not Redline should do the trick for you .
Burla
It's probably exhaust tick if neither PUP or Amsoil helped it.
Nutshell
Definitely lifter bleed down. Seeing as it's so sporadic, I'm hoping a better oil can fix this.
Do you know if Redline is trinuclear moly?
TheFactor
Oregon
That's exactly what I was thinking if it was a exhaust leak it wouldn't disappear for days at a time I wouldn't think . It would be rather consistent .
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
I honestly Can't see Amsoil Signature Series being the root cause of this issue!! It as well as PuP both are remarkably Robust Oils...
I am so thankful I made the switch to 5W-30!
I do hope you find the root cause of this issue and get it resolved ASAP!
