- Joined
- Apr 28, 2012
- Posts
- 23,487
- Reaction score
- 45,643
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
Kyle just run 0w16 you will get that mileage back.
LOLAlready am,
My local gas station carries their own brand of 0W 16.
I decided to run oil that thin because Chrysler designed the 6.4 with extremely tight tolerances. 40W oil won’t fit in between any of the metal parts anymore. Also I want much lower oil pressure because that obviously equals a lot more flow which is way better for my valve train when I have really long idle times.
To help even further I reprogrammed my PCM to run at a lower idle rpm’s to save more gas. I also lowered my shift point RPMs to help the engine lug a little bit more resulting in better fuel mileage.
Have an appointment next week to take my 488 gears out and and install 321s
Disclaimer,
Im full of ****
Lol and this is on SAEs website LOLGasp, oh whew he was jok'n.
Funny how a gov't can say that we are destroying the earth and the sky is falling, but order more polutive gas on a whim because gas prices were too high? The only break out the "climate change" card when it suits them. Wield the sword when you need it to explain short comings like blaming the fires for climate change, but then change an established procedure to help climate change because people are mad over gas prices. Force us into low oil weight mds engines because of their agenda, but then change their agenda when it suits them. Boys stop drinking their koolaid, and run some damn oil in those rigs. My momma always said drinking koolaid aint good for ya.
Guys read this **** when the gov't was half way reasonable, 2001. From Diamond Chrysler testing ******* 20 weight oils and READ their conclusion, ****. Viscosity is still the most important feature in an oil and hths is the best way to read a viscosity, but consider the triangle as a whole. That was from the folks at SAE.org!!
Two programs were conducted to study the relationships between engine oil rheology and crankshaft bearing wear. A Chassis Dynamometer test of four oils in four cars was used to explore and define the key variables affecting bearing wear. These results were used to design a Field Test of nine oils in 45 taxicabs in New York City. The test oils (SAE OW-20 to 20W-20) were formulated to measure the effects of viscosity, viscosity index improver, and detergent inhibitor package. Bearing wear tended to be either low and unremarkable or very high, particularly in the thrust bearings. Oil performance was best expressed as the frequency of excessive wear, rather than by quantitative wear measurement. There were many instances of very high wear in cabs operated with the lowest viscosity oils but none in cabs with higher viscosity oils. Non-Newtonian oils appeared to provide slightly more protection than Newtonian oils of the same HTHS viscosity, and a higher quality adpack also appeared to provide benefits. However, these factors were secondary to the viscosity of the oil. HTHS viscosity was a better predictor of bearing wear performance than oil film thickness.
JAPAN, they found a way to make us trade our trucks in early with cam issues and junk trucks with a lot of mileage left in them for their agenda AFTER 2001. Hmm, who took office after this? Don't be a sheeple. Ten bucks when sae figures out this old text they will take it down, lol.
Do you want another side with your fries and burger sir?
Yeah can you add some low viscosity high bearing wear oil with that?
LOL< cmon man. What else can I do for you fellas? I am outta tricks, if yaw'll still want that twenty weight I wish you luck on it.
sounds like you found a good oil, 0w40 edge?
So Kyle when is the hybrid motor and the CVT going in?
No.....
But i heard from a guy at work if you start using Amsoil than your wifes boobs will get bigger and you get an automatic membership to BITOG.
Sound like a good deal.
Are you serious?No.....
Are you serious?
Do I need to rub it right on them or have her drink it from a glass?
Sent from my Nexus 6P using Tapatalk
