TAILGATE LIGHT BAR AND BACK UP CAMERA
tomb
ontario canada
2012 bighorn-cherry red
I believe mine was wired to the 4pin plug but in a way to keep the socket useful-they add a wiring harness or splitter under the rear so the socket door stays closed-and you can still use the socket.
tomb
ontario canada
jinxed myself-had it problem free for almost 3yrs-3leds have gone out on drivers side now. I shouldn't have commented on that post.
Ohio5pt7
Ohio
I know this is old but does anyone have a link to the curt harness?
ThunderMug95
North Prince George, VA
It plugs in behind bumper...the harness from the chassis plugs int the “T” of the Curt harness, then the other side of the Curt harness plugs into the oem bumper plate. The 4pin tail is now free to plug into your light bar. All of it is hidden behind the bumper. Just ziptie up the rest of the slack. You may have to tap either the center white wire of the Curt or run up and connect to one of the reverse bulbs in tailight. This depends on your light bar I suppose. I have the Opt7 triple led redline, so I tapped into the center white wire of the Curt to power and send the reverse light signal to the led bar.
And yes, the oem wiring for a trailer will still work. The Curt is just a way to cleanly tap that harness securely and without a bunch of splices/soldering/ scotchloks etc. very easy install and looks like it came from the factory.
Ohio5pt7
Ohio
This is exactly the set up I was looking into. Thanks for the info
Sent from my SAMSUNG-SM-G891A using Tapatalk
BigDog1197
Plano, TX
Did anyone have issues with the spare tire hole access after installing the opt7 triple beam?
Ohio5pt7
Ohio
Is this the white center wire you are referring to?20190503_154850.jpg 20190503_154850.jpg
ThunderMug95
@Ohio5pt7 Its the center one, the other white’s are on perimeter. Absolutely positive on that part, theres only 1 center wire and its white. I just used a scotchlok and sealed it up.
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
Installed on my 2016 Laramie crew cab I think it is the best led tailgate light on the market 2000 cobb led lamps built into it also comes with 3 year warranty >>I also purchased a >>PUTCO Blade Quick connect Harness Part #529004 it is plug and play so you don't:Caffeine: splice into any wires on your truck it plugs into the 7 pin plug behind the bumper inline and has 2 tail wires for the power clean look and works well good luck P>S the light bar does not over power the back up camera it makes the surrounding area light up more
ThunderMug95
What do you sell them or something? Through what I can understand from your posts your pimping them pretty hard. How many LED blade lights have you installed on your truck? Just curious if your a dealer or something.
madtrucker2016
No not selling them just paid for mine online and trying to help out someone unlike you maybe you didn't buy one and your not happy with your brand but mine is really really good
ThunderMug95
Were all happy for you. Your brand is good and you love it. You bought it online and it the best on the market per your experience with the different manufacturers of tailgate Led bars.
The way you compose your posts leaves one to consider if you are in fact a user or a seller. Especially since this is the second similar post on this thread. Glad you cleared that up for us!
Enjoy your Ram!
madtrucker2016
Enjoy your Ram!
sorry that's how you interpret some thing after reading it but hey I take it your a guy that likes to bully other persons on line you can have a nice day
jhicks1983
