TCM...
Choppersicballs
Wilmington nc
So I recently bought a used 2004 1500 (had srt8 badges which I removed) and has been running fine.
I randomly got a check engine light a week back brought up a p0700 , however fluid is good truck shifts fine and no limp mode.
The little research I did said to get a new tcm or have it flashed.... however cant find anything online about it
Truck has 148xxx , also has a battery drain. (My guess is aftermarket stereo installed incorrectly)
Fast69Mopar
P700 in the PCM is a generic DTC that sets to alert you that a transmission DTC has been set. Since the truck is a 2004 model it has an NGC controller which means the PCM and TCM are combined I to one unit.
You will need to get a scan tool hooked up to see if there really is a trans DTC set.
P0700 also does not mean that the PCM requires replacement. Please don't waste your money.
HemiLonestar
Navy Badge Coast Guard
MD
Yeah, should be at least one more code in there along with it. Since you say the trans works just fine with no problems, you should be able to count out P0734 & P0735 (be happy lol).
C
Choppersicballs
Wilmington nc
The only other code was an evap code for my gas cap or what have you.
The 0700 comes and goes randomly.
