Adamc23
2004 ram 1500 5.7L hemi
So my pulley system is squealing like a *****, I'm replacing part after part and kind of want to stop throwing money away, I replaced three pulleys and the belt so far.
I replaced two pulleys because it had a slight squeal then everything was great no squealing at all no sounds everything was good. After about 10-15 days it started to squeal worse than it ever has.
Replaced the serpentine belt, 1 day of no sounds, next day squealed even worse!
Replaced the Idler pulley and right now I start it up and the sounds are painful. Also sometimes when it's cold started the belt tensioner flaps, no squealing just flaps, and after the engine warms up it stops flapping and squeals again
Upon holding a long screwdriver up to some pulleys I hear no sounds, even tried a stethoscope.
Here's what I believe the problem is, the spring in the tensioner must be shot therefore requiring a new tensioner arm, from taking the belt on and off plus its age i guess it's worn? Anyone ever have similar problems? Any input what the squealing could be? Lastly where could I find a good cheap tensioner arm or bracket or whatever you want to call it.
