thought ram was slower than should be..
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Edited....apparently I expected too much from a 400hp rcsb at 6k DA.
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Oh, and its a plain ST
huntergreen
Marine Corps Navy Badge
In 2003, I test drove a hemi 1500. I remember being slammed into the seat during the test drive. I ended up buying a Cummins. I bought my 11 sport from the same dealer and went on the same test drive. The hemi has had been neutered by the nannies. In this case, it is the torque management used to protect the drivetrain.
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Thanks.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Gears, stall convertor & custom tune only way around torque management if you plan on keeping.
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Thanks
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
Not saying this is gonna solve your trucks slowness, but you might have better luck with higher octane gas. Not saying dump 100 octane in your tank, just something a few points higher
crackerjack1957
Going to say I was wrong on that 0-60 in 6-7 secs unless you had 4.10 gears.
I don't think it should be over 8 secs though.
Below is stated under check inventory at site below.
"Equipped with the HEMI, the 2012 Ram R/T regular-cab 4x2 model with a short bed and 4:10 gears blasts from 0-60 mph in 6.1 seconds."
https://www.bedardbroschryslerjeepdodge.com/2012-ram-1500.htm
Pull Ya
Cedar Creek, Tx
I think maybe you should check your routine for timing your truck. Go to a strip and do it right--you might be surprised. A lot of trucks are all over the map when you compare 1/4 times. It depends on your mods, your traction, and most of all, whats behind the steering wheel. There is always going to be faster trucks---no matter what you do or don't do. Like I said, start at the drag strip and get a ACCURATE baseline to work from.
Jay
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Thanks. No access to a track.
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
I know rhe 1/4 mile through an app is all over the place, Im more concerned with 0-60 since its pretty easy to measure
Pull Ya
Cedar Creek, Tx
Your gears and the 6 speed are killing your 0-60. Do some research into the Pedal Commander. It might have a positive impact on your 0-60 times.
Jay
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
That does seem ridiculously slow. Even for the old junk 5 speed. Feel like something is wrong with that truck. Motor Trend tested one of those at like a 5.9 0-60 back when it was new. How many miles are on the truck? Does it need any maintenance? The trans and gears suck but it should be running better than that.
You also can’t discount environmental factors like heat, elevation. It is summer and you are in the desert. But 0-60 in the 8’s seem excruciatingly slow for that even in the dead of summer.
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
This was 2 days in a row, in the 60s around 5am. Maintenance appears to be fine, as the dealer supposedly checked it all out and got it up to date (received a chrysler warranty, so they should have)
60k miles.
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Jay
Pedal commander is in work, but there seems to be another issue somewhere.
Truck seems really well take care of. But who knows.
huntergreen
Sounds like something isn't right. You sure it's got the hemi ?
Pull Ya
Cedar Creek, Tx
Check the spark plugs--suppose to be changed every 30k also check the air filter and throttle body, and the tire pressure. Are you manually shifting and at what rpm? Don't stand on the brake and the accelerator at the same time on the line---it will pull timing if you do.
Jay
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Its a hemi lol
Tire pressure good, not sure how to tell if k&n cai filter needs washed. I will check the plugs and throttle body.
The shop had to swap a head because of a broken bolt, so surely they would have noticed something dirty in the throttle body.
Tires are properly aired.
