Timing chain slop
Dodgeguy44
Red Deer, Alberta
Cummins 6.7
2011 1500 5.7 hemi has a Code P0016. The timing chain seems very loose/sloppy in my estimation but how much is too much and would that cause the code?
Burla
2010 Hemi Reg Cab 4x4
Search the forum, cam phaser I believe is more common, or even just the sensor.
OCDTech
Louisiana
Curious , oil type weight, maintenance intervals? Mileage?
Dodgeguy44
Dodgeguy44
Red Deer, Alberta
Cummins 6.7
I bought this engine rebuilt and it has always shown this code. I took the front end apart and found the timing was quite a ways off so I reset it and still have the code appearing. New cam phaser at the same time but no one had a new chain. Oil is 5w-20 synthetic. I am thinking that the timing chain was not replaced when or if the engine was rebuilt. I have put about 10-12000 km on it since installing the engine.
OCDTech
Louisiana
I see oil control solonoids where the screens come apart can give this code, but its usually accompanied by another code. So you may be on the right track, it says this code will be set when a predetermined amount of degrees of timing is off. Doesn't say how many.
Dodgeguy44
Dodgeguy44
Red Deer, Alberta
Cummins 6.7
Thank you for the replies. I am tearing it down again tomorrow and wanted some ideas. Thanks again.
