NickSteel
- Feb 28, 2020
- 107
- 55
- Location
- California, US
- 2013
- 4.7L V8 Magnum
This is my atleast 10th post on this truck because of the absolutely horrid transmission. The truck is a 2013 4.7L with the 65RFE.
Before i start, yes, the fluid is changed religiously and at the moment is bright red.
Okay, so now, to the issues. Holy crap are there a lot.
Firstly, the truck hesitates in 1st gear until let’s say 2100-2200 RPM where it jumps around 100-200 RPM to 2300 and starts to go.
Secondly, it hesitates when you’re at 40 and try to speed up to 55, causing you to have to floor it to get up to speed.
Thirdly, the shifts. Oh my god are the shifts in this truck horrible. There’s a very loud high pitched whining noise the truck has had since new, but to get back to the shifting, 1-2 causes the truck to jolt forward, 2-4 is sloppy at best, the RPMs hang at around 2500 for around 1 second and then drop to 1K, and then 4-5 is ok at best. 5-6 is ok too. Now, up shifting is another issue entirely. Going from 6-5 slowly results in the truck being able to rev freely from 1.5K to 1.9K (but it gains speed when it does this, so is it actually a slip?) and then it quickly downshifts into 5th.
Seems to be another issue to where if you slow down, and hit the gas to speed up real fast, the RPMs jump 300-400 and then go back down. And to put the cherry on top, every time it shifts into 4th or 2nd prime, there’s a loud clicking. This truck also lost reverse for around 2 days last year but it fixed itself with a fluid change.
The engine is on original plugs and wires at nearly 100K, could THAT have anything to do with the shifting?
I love this truck but i can’t drive it anymore because it’s such hell. Thank you for any help.
