To plug or not to plug
URdone21
CA
2013 Quad Cab
The bottom air duct on the S&B CAI. Plug it or not? Thanks
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I'm the opposite. I left mine open. That lower scoop is in front of the engine, so it will only help draw in more cool air. I would only plug it if you do a lot of offroading and are worried about getting water/mud in there.
URdone21
URdone21
CA
2013 Quad Cab
No offroading for me. 95% city driving.
audio1der
Airdrie, Alberta
GET THE SCOOP!!! LOL
I'd leave it open and let it breathe as much as you can.
URdone21
URdone21
CA
2013 Quad Cab
Open it is! Thanks guys
HLram
2012 and 2007
Hemi 5.7 in both
I've tried both ways and did not see even a single degree of difference in air intake temps while driving. Sitting and idling though, I saw a huge difference in mine. It was actually alot hotter AIT with the plug IN PLACE! I was VERY surprised. I would have thought it would have been alot hotter idling with the plug removed because the engine heat going into the bottom of the spout. I was wrong. I idle alot at work and my temps can easily get way over 120+ degrees idling. Also, I have noticed a 12-14 degree temp increase over ambient temps while driving with the S and B, no matter what the outside temp is. Whether it was 50 or 95. Same thing, 12-14 degrees hotter than outside air. The factory airbox was always about 7-9 degrees warmer than ambient temps. This is just on MY truck, not saying all others will be this way. I am going to insulate the intake tube and box this week with some homemade lizard skin and see if it will help lower the temps. I know it will be a little warmer than ambient because of the tube coming from under the oil fill cap area. But I just want to see if it will help a little.
kkreit01
Olathe, KS
Open -- unless you plan on crossing 2' streams.
