- Joined
- Apr 28, 2012
- Posts
- 27,542
- Reaction score
- 57,751
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
Since the above posts were specifically mentioning a chain to a hitch BALL and you didn’t specify otherwise, you can see how one would come to the same conclusion I did. Hitch shackles are safe, hitch pins are meh, as the pin can bend (it’s not designed to take the force from a source that flexes and doesn’t distribute the pulling forces across the pin as evenly as a metal attachment does) but will work in a pinch. Using a hitch ball as a recovery point should never even cross someone’s mind as a viable option, and WILL kill someone when it fails.
I did, I specified hitch, not hitch ball, if I meant hitch ball, I would have said hitch ball, only a darwin would use a hitch ball for a recovery. You mis read it. Hitch and hitch ball are two completely desperate things, the hitch is attached to the frame, like I said. A hitch ball is attached to the hitch, not the frame. I'm not sure how more clear I could have been, whatever bro. It may be possible for an accessory to adequately cover the ball and that may be an option, but I personally haven't ever seen that. If it locks and is attached to the frame, it is good to go. If the tires are pointed in the same direction, good to go.
