Towing, Airbags, Tires & GVCR
OkotoksChris
Alberta
6.4 HEMI
Guys or gals, need your input, please.
We purchased a 2019 RAM 2500 Laramie Longhorn /w the alcoholic 6.4 HEMI (not the best, I know) and the 3.73 gears. Tow capacity -
Tow Capacity - 14,410#
GVWR - 10,000#
GVCR - 21,500#
Payload - 3380#
Hitch/pin weight - 1800#
Tires: LT285 60R20 (E) 8 Ply
Here is where I need your input. We are in the process of buying a Travel Trailer or 5th Wheel however everything we like is 500# to 2000# over the GVCR of the truck which poses DOT issues in various States and British Columbia.
So my thinking is to install airbags for the rear suspension and changing to 10 Ply tires.
Thoughts?
mlrtimemach
US
2019 Ram Tradesman 4X4
Air bags won't change the over all weight but it will help the ride an leveling of the truck. I don't have them but talked to people that have. I haven't invested in em because our travel trailer only weighs around 6,700ish lbs depending on where we are goin so the truck sits level using weight distribution hitch. Tradesman 2019 2500 with 6.4 an 3.73 gears.
P.S. do not go by what the tag on the camper says as far as what it weighs. That is factory weight an doesn't include things like propane bottles, batteries etc. And Its amazing how quick you can reach the max trailer weight with so little once u start loading it.
If your bound by the GCVWR in Alberta then about only thing you can do is weigh the truck to know how much you have left for a trailer. Some states allow you to plate the vehicle for GCVWR also know as Elected Gross Weight, then your just bound by the GVWR and GAWR ratings.
You might not like towing north of +12K lbs through the mountains with the 6.4l, keep in mind the engine gets derated the further up in elevation you go.
The airbags will help control the sizable load your looking at but in reality doesn't change the legal aspect unless you can get it certified.
You truck should already have Load Range E tires(10 ply), you could go up to Load Range F but the Transforce E tires are good for 3600 lbs
O
OkotoksChris
Alberta
6.4 HEMI
Thanks. I lead to believe that the air bags would allow an increased of weight to the overall GVCR, and that going to a 10 Ply tire would also allow for additional load capacity. Still learning on my part to do.
O
OkotoksChris
Alberta
6.4 HEMI
MLRtimematch or anyone else. We have found a trailer that is within the load limits however it’s 37 feet long; 10800# GVWR. Pulling that length doesn’t scare me but the fishtailing is a concern considering the size of the truck. How much do stabilizers bars really work with that length?
mlrtimemach
US
They will help tremendously. Research them carefully an find what you are comfortable with. Like everything else there's a million opinions about weight distribution hitches an which is best. What it comes down to is how much do you want to spend. Our trailer is 30ft long including the tongue an I don't have any sway.
mlrtimemach
US
An I recommend doing the 3 weight rule. Go to a Cat scale an weigh the truck and trailer hooked up. Then weigh it without the weight distribution hooked up then weigh the truck by itself. That will give you the toung weight an every other weight you'll need. Weigh it loaded like you would be goin on a trip so you get accurate weights
olyelr
Kewadin MI
Adding bags (or any aftermarket item for that matter) will not change the legal weight rating for your truck. What it comes listed with from the factory is what it will always be.
I use a wd hitch and air bags on my power wagon for our 8000 pound travel trailer. Works great. I would not ever tow a tt without a wd hitch...ever.
I only added bags because after I leveled the truck it was low out back when towing the tt, even with the wd hitch.
star_deceiver
Airdrie, Alberta
3.6 Pentastar
The sail will pull your mileage down to 26-32L/100kms. Worse when your ripping through a Utah headwind at 130...
Keep your trailer at a reasonable size for your 3/4 ton and you will have no issues with the hills in BC... just remember that you’ll be paying $1.40/L or more for 89.
Dr J Cumminz
Anchorage, AK
6.7L with Aisin
I second the notion of using a WD hitch. That will keep you going straight. You should be fine with that size trailer, but just keep down the excess accessories and stuff. I. E. Too much wood, heavy stabilizers, large generators, empty your tanks frequently, etc...
Firetruck41
Washington State
2500 Mega Cab Hemi 5.7
Pretty sure that anything over 5k lbs requires a weight distributing hitch per the owners manual.
phorrestphire
