TPS adjustment
DaKing
6.4 HEMI
2011 3/4 ton, with TPS.
Current tires, Goodyear MT/R Kevlar, factory size ~ 65PSI
New tires , Goodyear MT/R Kevlar 35" tires. Tires say MAX 35PSI.
So, when I install these tires at 35PSI, I'll get dash errors and radio NAV errors saying tire pressure too low.
Whats the fix?
loveracing1988
Clarkston, MI
Your first problem is towing, I would bet the load capacity of those new tires isn't that good if they only take 35 psi. A tuner might be able to adjust the tpms otherwise your going to be stuck with the light being on.
cgeorgemo
Joplin, MO
3.6 Pentastar
Aren't they the same tires in a different size?
jbmobbs
murfreesboro, tennessee
I put a set of those on a 3/4 ton a few days ago at work......I put 60 psi in the rears and 50 in the fronts.
****! I hope hes ok :) lol jk we never go by that crap on the side walls. hell we put 80 psi in transforces on pickups
jbmobbs
heres a million dollar solution.......remove the bulb from the cluster........oh ****. u cant stupid technology!
that's what I love about my cave man ages truck. my air bag light came on so I fixed it. I un plugged my air bag and removed my bulb from the cluster.....issue solved :D
jadocs
The truck still thinks you have E rated tires, but you put on lower rated tires.
cgeorgemo
Joplin, MO
3.6 Pentastar
Whats the fix?
What does the sidewall on the current tire say for max PSI?
joshhhh
