TPS adjustment
DaKing
6.4 HEMI
2011 3/4 ton, with TPS.
Current tires, Goodyear MT/R Kevlar, factory size ~ 65PSI
New tires , Goodyear MT/R Kevlar 35" tires. Tires say MAX 35PSI.
So, when I install these tires at 35PSI, I'll get dash errors and radio NAV errors saying tire pressure too low.
Whats the fix?
loveracing1988
Clarkston, MI
Your first problem is towing, I would bet the load capacity of those new tires isn't that good if they only take 35 psi. A tuner might be able to adjust the tpms otherwise your going to be stuck with the light being on.
cgeorgemo
Joplin, MO
3.6 Pentastar
Aren't they the same tires in a different size?
jbmobbs
murfreesboro, tennessee
I put a set of those on a 3/4 ton a few days ago at work......I put 60 psi in the rears and 50 in the fronts.
****! I hope hes ok :) lol jk we never go by that crap on the side walls. hell we put 80 psi in transforces on pickups
jbmobbs
heres a million dollar solution.......remove the bulb from the cluster........oh ****. u cant stupid technology!
that's what I love about my cave man ages truck. my air bag light came on so I fixed it. I un plugged my air bag and removed my bulb from the cluster.....issue solved :D
jadocs
The truck still thinks you have E rated tires, but you put on lower rated tires.
cgeorgemo
Joplin, MO
3.6 Pentastar
Whats the fix?
What does the sidewall on the current tire say for max PSI?
No members online now.
crcraft
