tranny problem
fastram05
when my truck is cold and i start it, put it in drive i actually have to rev it while in drive to about 3k for it to move, it doesnt do this very often. wild its still cold if i stop at a stop sign it will stall out. is it my tranny going out or just need to change the fluid and filter?
RonJon '06
Southern Minnesota
A clogged filter can make it act like that so if it's overdue for a fluid and filter change I think that would be a good place to start.:welcome:
ExpressRules
Southern New Jersey
2019 Big Horn Crew Cab
I once had a Dodge van that acted like that. I was in fear the tranny was dying but as a cheap last resort I had it flushed and was good as new.
F
fastram05
would this make me loose power..as in towing power?
natasha85
need help
i have the 545RFE transmission and had to replace some parts and there's a plastic shim in the planatery gear where can i get it can't find a part mumber
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Start with drain, filter(s) change and refill. Then see how it is. If it is full of metal in the pan it is much worse than just a little issue.
$miley
