chrisbh17
- Oct 12, 2017
- 6,720
- 7,525
- 2017
- Hemi 5.7
I was thinking I need to find the stock doge connectors or ones that will fit and make this a direct mod no cutting splicing or anything needed and no footprint of it ever being there. It'd just be a mount switch pick up power and ground and done.![]()
I like your thinking.
Is it in 8 pin connector by any chance?
Can it be taken a little further and connected completely INSIDE the truck? i.e. near and/or right behind the 4WD switch.
Also, I have a chart showing the expected resistance values of a 44-45 switch....Im curious if the 44-44 switch has an extra value (4-Auto). If that is the case, could you wire it all up so the relay is only triggered when the switch is set to 4-Lock? Essentially giving you a *real* 4WD lock, with the ability to keep 4-Auto, but now it would all be automatic (you could put a toggle switch in for override)
Electrical isn't my strong point, so essentially by hitting that toggle switch its forcing the clutches to engage and giving you constant front driveshaft engagement? Am I understanding this right?
That is my understanding. Instead of varying the voltage and/or resistance, this setup gives a constant voltage and/or resistance, "fooling" the encoder to keep the clutch fully engaged. As far as heat or durability being an issue....my take on clutches is that friction (and consequently heat) is generated as they are engaged and disengaged. Keeping them engaged, I would think, would not cause any more friction than "normal" usage. In fact it should cause less. The only thing that I could see happening is if the material they are made of cant hold up to real 4-Lock even though the button says it should
