Tom8
Anyone has the issue of their transmission coolant line at the connection end leaking? There is two lines and one of which, the clamp end seems to be leaking. Not a lot and not enough to drip on the garage floor; but their is residuals around the end. It is easy to replace that line? I assume the leaking line is the hot line since that likely takes the most abuse on those end points.
