- Joined
- Apr 28, 2012
- Posts
- 27,541
- Reaction score
- 57,750
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
Ramps, cheap and easy. Good info wild..
Hi All,
Isn't there a special aftermarket transmission pan with filter for 8 speed that makes it easier to change transmission fluid and filter? Or am I thinking of aftermarket differentials covers?
Thx
How about Mag-Hytec ? Do they have a transmission pan for the 8 speed? Their site is a bit confusingThere's the PPE deep pan for EcoDiesel which has the same transmission. That's what I'll be swapping to when I service mine since it holds more, is actually metal, and has replaceable filters. If I remember correctly it should clear on the Hemi without doing any exhaust re-routing, but I could be wrong.
Since they mechanically heat the 8 speed and it has a very thin spec, it is a certain type pf base oil. Also, you likely need to do transfer case, is it a 4x4? Maybe h395 will pop in or PM him, he has options other then the unicorn fluid Ram asks you to use, I believe specifically for a 2014, I don't know what other years have that transfer case? Do you have the 8 speed or the 6 speed? Very different flush procedures.
Hello, I'm new to this forum and want to ask if anyone has done a transmission flush on their 5.7 hemi. I haven't found much info on the flush vs. Fluid change. I have 105,000 on my ram 14 sport. The manual states this is a lifetime oil. Doesn't even have a recommended fluid change interval. I pull a heavy ( bumper pull) horse trailer.
I want to change fluid because I'm sure it needs it. Thanks.
will the tubes on this fit down the dipstick tube on the 6 speeds? I have a 2011
It should as it is larger than an oil dipstick tube. Unless your asking about length. That I am unsure as I do not have a 6 speed to measure.will the tubes on this fit down the dipstick tube on the 6 speeds? I have a 2011
I inquired at the dealership about servicing my transmission on my Hemi 5.7 2015 as I tow a camper. The service manager told me that there is no way to drain and service the transmission because the drain plug will not be usable . My thoughts are that the whole pan/drain plug would need to be replace if you drain it. The extractor/filler solution listed in previous post is another option.
