RamCares
Hey guys. I’ve got a 2015 Mega 2500 with the 6.4. I will preface this with the fact that I had an issue while towing a while ago where for some reason the tranny stuck in fourth gear. I limped it home and checked the fluid and it was fine. Shut the truck off for a bit and when I turned it back on all was good. Didn’t have another issue. I did call the dealer and he told me to check for codes, I did and there wasn’t any. So essentially he told me to wait until it did something again.
I just hit 60k and since I tow a 4K trailer 4-5 days a week I changed all the fluids. Oil, both diffs, transfer case, and transmission.
I dropped the pan, cleaned it up, replaced the filters and put it back. Everything seemed fine. Fast forward five days to today, and twice when I went to start the truck and drive off, it only sort of went into gear from park. Did the same thing when I shifted into reverse. I noticed that it wasn’t ‘going’ when I hit the pedal, so I put it in park and turned it off. When I restarted again after a few seconds it was fine again. Went into drive and acted normal.
I’ve been checking the fluid level while hot and it’s right at the second dot on the hot side. Maybe it’s too full? I’m not sure what symptoms that has...Other than that it seems to shift smoother and quieter than before, but it could be my imagination.
Is there something wrong here? Should I vacuum out some of the fluid?
My truck has went into limp mode (stuck in 4th) and I believe it is due to the transmission solenoid recall. Have you had it done?
Hi Ionicbrick & Iron Outlaw,
Sorry to hear you are experiencing transmission concerns. If you decide to connect with your dealers, please feel free to send us a private message. We would like to ensure that your concerns are formally documented, as well as connect you with Case Specialists that could work alongside your dealers to find a potential solution. Let us know if you have any additional questions at this time.
Mark
Ram Social Care Specialist
