SitKneelBend
Moderator
Member Relations Specialist
- Jan 8, 2015
- 10,988
- 7,680
- Location
- St. Louis
- 2014
- 3.6 Pentastar
Those need to have the truck on all 4 wheels BUT the levels won't be nearly as off as the transmission would be. IN fact, the transfer case and rear diff would likely be slightly overfilled and the front diff would be slightly lowLet me ask you fellas another question about the front/rear differential fluid levels and transfer case levels.
I did those while I had the rear end jacked up about 9 1/2 inches to level the transmission. Is it OK to do it that way?
Or is it best to level the wheels front and back equally to check those levels? I want to make sure I’m doing it the correct way.
Thanks
