Trinity t100 Pids
LB3711
Trumbull, CT
3.6L V6
Whats the best PIDs to put in to monitor/log to use on the programmer? I'd like to set a log up but not sure what to make up.
Hemi_Express2013
Nantucket, Ma
depends on what you are trying to accomplish. Some of the obivious are: 1) P-ratio, 2) base spark, 3) Actual spark cyl 1, 4) KNK fuel retard, 5)knk st retard, 6) knk LT retard, 7)Engine RPM,8) Current vehicle speed, 9) Throttle blade position, 10) throttle position sensor percent, 11) and the most important... AFR.
hope this helps.
BlownGP
Houston/Baton Rouge
hope this helps.
That's pretty much it, but AFR will not be accurate on a narrow band.
