Trying to figure the lift out for my truck air delete
Weberj1010
Jax il
3l
I have a few questions
1. why do I need to change the upper control arm if I am changing the air ride out. Because of the height.
I want the same height as off road 2 (no idea how high that is . anyone have any tips on figuring that out)
I also would like for it to sit level as well.
if there is already a post about this could you please link it because I can not find it.
thanks Weber
retroboomin
Alabama
there are lifts for the air ride. rough country and I BDS has one.
If you're taking air bags off you would prob want at least 4 inches of lift.. 6inch is the most common
Curt Gobbell
Memphis TN Area
HEMI 5.7L
Weber, what do you plan to do with your air suspension components after you delete them?
BWL
Embrace the skeptisism
BC Canada
Or2 is a 2" lift front and 1.5 rear so no upper control arms needed. Could do bilsteins in the front set to 2.1 and either get longer coils for the back or run a 1" spacer and be pretty close to level if that's what you want or go 2" in the back to end up with stock coil spring truck rake. The air suspension has less rake in OR2 stock. About an inch.
W
Weberj1010
Jax il
3l
Hey thanks for the info I'll repost with what I come up with. Busy fixing another car and little ones sports
W
Weberj1010
Jax il
3l
Curt I am not Shure yet still hammering out what to do. I kind think it some kind of switch or valve or relay thats bad cuz all the shocks hold air. If u want 1st shot at the parts shoot me a pm. So I remember
Maybe put on the eBay as used parts
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
The Bilstein or eibach kits are the entry level options. I’ve done a few air ride conversions in a lot of different configurations. @Nick@GotExhaust can set you up
TMFMK
