Tune Adjustment for CAI and Catback?
sbuko213
Arcadia, FL
6.7 HO
So I just put on an S&B CAI and Flowmaster American Thunder catback on my truck yesterday and it sounds and runs sick! I'm also running a 87 DS can tune right now. Will I need to make adjustments to the tune for the added flow? I haven't thrown any codes, it's just a concern.
RLJ10X
Southern Indiana
I'd spent the little extra, and get the Hemi Fever Tunes for life. They're a bargain.
sbuko213
sbuko213
Arcadia, FL
6.7 HO
I'm considering getting the 89 tune in a few weeks. Just looking to see if any immediate adjustments are necessary.
homebrew
Cummins
Have you disconnected the battery to reset the PCM ?
DavidRam
SoCal - Redondo Beach
2012 RCSB
You won't necessarily need to make changes to the tune, but I would disconnect the battery for 2 hours.
homebrew
Cummins
What you are doing basically is dumbing the computer down to stock set up. Once you reconnect the battery and start driving it will start learning which is nessisary because you now have more air flowing in and out of the engne. If you don't reset the computer you basically have expensive paper weights because the computer doesn't recognize there is more intake and exhaust available.
sbuko213
sbuko213
Arcadia, FL
6.7 HO
That makes sense. Will I need to reload the tune or is that good still after that?
BlownGP
Houston/Baton Rouge
Okay. I haven't thrown any codes. Is that just a safety measure?
The computer learns as you drive. You are pretty much just it have it start for scratch when you dis-connect the battery. Do you have to do it, not necessarily but it won't hurt anything.
sbuko213
sbuko213
Arcadia, FL
6.7 HO
Cool guys, thanks for the advice. I'll do it when I get back from work.
