U connect. Turn off second i phone so it does not play over speakers
lAWROSA
GALIVANTS FERRY SOUTH CAROLINA
My son watches you tube videos in the truck and wants to charge his phone. But the sound from his phone plays over the speakers.
I plug my phone into the other usb and is CarPlay.
On I phone we tried the small box on top right in you tube but there is not line item for i phone speakers.. so his keeps playing over the speakers until he unplugs it.
How do I get his phone to stop playing through speakers while plugged in?
anyone?
chopperman1
Peoples Republic of Massachusetts
2018 Rebel
5.7L HEMI
Install a usb adapter in to your 12v power port and have him use that. The "truck usb ports" are used for interfacing with the u-connect are doing what they are supposed to do.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
anyone?
There should be 1 USB port on the dash that is power only.
lAWROSA
lAWROSA
Nope just two usb under arm rest for u connect.
12 v power port in console and one at rear seat center. Ill just get a black i phone brick for him and plug it into the inverter on dash.
cityredneck
arlington, tx
my 2017 has a power port in the rear of the console near the bottom for the backseat, if your son sits in the back.
if he sits up front put a usb charger in the port inside the console, under that cellphone holder thingy (sorry, dont know the correct name)
Under the console phone holder, there should be a cigarette lighter
You can remove the lighter itself & insert
Or remove the top of the console, 3 screws under the rubber pads
marked with blue tape
blue plastic piece is the cigarette lighter, it comes out fairly easily
replace it with one of these
12V/24V USB Outlet QC 3.0 Dual Charger Socket with Touch Switch DIY Kit for Car, Golf Cart, Boat, RV, Motorcycle, Truck and More​
