Raife
- Joined
- Aug 18, 2022
- Posts
- 69
- Reaction score
- 35
- Location
- Texas
- Ram Year
- 2020
- Engine
- 6.7 I6 Cummins HO Turbo Diesel
Evening all. I installed the OEM bed light kit and was working under the dash and under the fuse box. I also unpluged (but repluged) a couple other units under the dash to get to the CAN block I needed to. Now I am throwing a U0101 code. I also wired the KaodTech bypass to the CAN units.
Open in the CAN bus + circuit
Open in the CAN bus - circuit
Short to power in either CAN bus circuit
Short to ground in either CAN bus circuit
Rarely - faulty control module
Read more at: https://www.obd-codes.com/u0101
Copyright OBD-Codes.com
Is this something to be worried about?
Thank you.
Thank you.
