UCA’s and Eibach Pro-truck 3.5 lift?
Bajones9181
Bloomington
I know that going much over 2.5 up front on a stock setup can start to present some geometry issues. I will be installing the Eibach pro-truck lift on my 2013 sport soon. This kit has the 2.75 lift and a 3.5 ‘heavy bumper’ setting as well. If I combine geometry corrected UCA’s such and the Zone’s with the 3.5 lift will my geometry be ok or are there still some geometry concerns at that height even when combined with the UCA?
BOWERSFJ
Uniontown OH
CV angles might be a bit much I would think ...
JB1
Houston, Texas
The UCA will correct the upper ball joint angle, but your tie rods and CV axle angles "might" be a little extreme. You could always try it, it would be no worse than the 3.5" ready lift they sell.
novelmike
Central California
I think that’s the reason most coilover shocks don’t recommend are 2.5” max. They don’t wanna be liable for damages to drivetrain.
Nick@GotExhaust
Preferred Vendor
SC
Both of these posts are exactly my thoughts. You are still going to have CV angles that will be extreme. Exactly why coil overs dont offer that much lift. extreme CV angles and off roading will cause premature failure. street driving and extreme angles will also cause issues eventually.
B
Bajones9181
Bloomington
Thanks for the feedback. That was my concern. Definitely want to stay away from as many issues as possible so will stick with the 2.75 setting.
JB1
Houston, Texas
novelmike
Central California
If you need to level out the rear of your truck, there’s a guy the has new Icon coil springs for sale!:wave:
Reactions: JB1
